Goodbye Encore, hello Soul!
by csandste
04/21/18 12:34 PM
7.3 drain plug torque
by mobilaltima
04/21/18 12:26 PM
'09 Kia Sedona - to change or not to change (oil)?
by Number_35
04/21/18 12:19 PM
I Think Spring Is Finally Here
by Warstud
04/21/18 11:48 AM
NAPA GOLD 7055 UN USED CUT OPEN
by car51
04/21/18 11:26 AM
Broken Cat
by Stelth
04/21/18 10:32 AM
How often do you use your moonroof?
by mclasser
04/21/18 10:29 AM
Weird Electrical Issue.
by George7941
04/21/18 09:35 AM
Ever puchase movies from cable provider?
by ZZman
04/21/18 09:31 AM
Mann HU 711/51 X oil filter for Miniís $6.50 Amzn
by 1JZ_E46
04/21/18 09:30 AM
M1 Oil For My Trucks Engine
by BlueOvalFitter
04/21/18 09:30 AM
Toyota SofTex upholstery
by CincyDavid
04/21/18 09:09 AM
Castrol Dexron VI $5 QT at AA
by The_Cams
04/21/18 08:41 AM
Liqui moly engine flush
by gallydif
04/21/18 08:27 AM
Uneasy about Bosch Cartridge Filter
by tc1446
04/21/18 07:36 AM
Harvest King 0w20 Full Synthetic
by oilstudent24
04/21/18 07:22 AM
oil spec.
by ernied
04/21/18 07:03 AM
Great dog story to start your day!
by AZjeff
04/21/18 06:51 AM
BITOGers in the wild west
by Shannow
04/21/18 03:54 AM
'10 Wrangler 5,350 Miles Cam2 5w30 Synavex
by montero1
04/21/18 03:31 AM
puma4440, zeroyon223, wade12345, rdatman, mowermon
64805 Registered Users
78 registered (andyd, alphadog, Astro14, 2015_PSD, aquariuscsm, 1JZ_E46, 4 invisible), 1784 Guests and 46 Spiders online.
64805 Members
68 Forums
282065 Topics
#4288904 - 12/30/16 01:29 PM Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles
k1rod Offline
Loc: Arizona
Oil not changed. I think I am going to try for another 10K miles. Oil filter is a Royal Purple Synthetic media filter.
Edited by k1rod (12/30/16 01:37 PM)
#4288919 - 12/30/16 01:49 PM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: k1rod]
FlyNavyP3 Offline
Loc: Jacksonville, FL
Good looking report for your Duramax. How long has the oil been in service time wise? How is the truck used? You're no where near the lube condemnation limit for iron and the TBN is still pretty darn strong. I'd estimate without knowing more about the application that an additional 7,500 miles should be safe and likely if the truck is used for the next 10,000 miles like it was for this 10k then you'll probably be alright with another 10k.
Any makeup oil added?
Luke
#4288956 - 12/30/16 02:25 PM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: FlyNavyP3]
k1rod Offline
Loc: Arizona
Hi Luke, The oil has been in service for one year and two months. During that time I added 1/2 of a quart of makeup oil. The truck is used in mixed service from being pressed into service as a commuter vehicle (both around town and highway) when my regular daily driver is in the shop, to hauling heavy loads of concrete roofing tile or whatever else I need to haul in it. I used to tow a 6000lb travel trailer around the country but haven't done that since this oil was installed. Actually I don't think I've done any towing on this oil. -Rod
Edited by k1rod (12/30/16 02:25 PM)
#4289127 - 12/30/16 05:16 PM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: k1rod]
roadrunner1 Offline
Loc: oh
The Duramax is known for shedding CU, its thought to be from the oil cooler and doesn't hurt a thing. Sample looks great, keep on trucking.
'15 F350 6.7
#4289301 - 12/30/16 08:52 PM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: roadrunner1]
k1rod Offline
Loc: Arizona
Thanks! Some of them do and some of them don't. I was wondering if the ones that do shed Cu are the ones that have the tow package option. I think the tow package option is what gives you that Copper oil cooler.
#4300878 - 01/12/17 08:48 PM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: k1rod]
dnewton3 Offline
Loc: Indianapolis, IN
There is no "tow package" with a Dmax truck, in terms of the engine and it's supporting equipment. You don't get a different oil cooler, etc. They are set up to tow from the factory.
The oil cooler is in the block right behind the oil filter mount. They use Cu in the construction. It's not uncommon to see Cu elevated when changing brands of oils, especially some brands of syns (I cannot explain the chemistry as to why it happens, but I accept that it does). As i understand it, the Cu will essentially oxidize (normalize) after a brand chemistry is established. Changing to another brand may or may not cause a reaction as it "normalizes" to the next chemistry package. This has been a noted phenomenon ever since the first LB7 Dmax came out.
Some of these images appear to show a sandwich plate design, and certainly appears to be Cu plated. However others look like aluminum. (ignore the obvious aftermarket type images).
see this:
http://www.bing.com/images/search?q=dura...&ajaxhist=0
You're UOA is fine. Leave the oil in there.
Edited by dnewton3 (01/12/17 08:49 PM)
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
#4300889 - 01/12/17 09:03 PM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: k1rod]
spasm3 Online   content
Loc: North Carolina
Plenty to TBN left, not a lot of silicon or soot.
P.S. Welcome back dnewton3 !
Edited by spasm3 (01/12/17 09:04 PM)
13 elantra 67k 5w30 QSUD
03 chevy avalanche76k synpwr 5w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 2200 miles m1 0w20/0w40 mix
#4301186 - 01/13/17 08:47 AM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: dnewton3]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Welcome back, Dave! There are two threads of interest to you here and here.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4303944 - 01/16/17 08:56 AM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: k1rod]
beanoil Offline
Loc: Midwest, Illinois
Off topic...
Good to see dnewton back after a 9 month absence. Stuck on a carnival ride? Pregnant?
beanoil: Tough under heat, real dirty afterwards.
#4305903 - 01/18/17 09:32 AM Re: Mobil Delvac 1 5W40 - LLY Duramax - 9750 Miles [Re: k1rod]
daman Offline
Loc: Bad Axe, MI
We do 20,000 on our farm Dmax's, there easy on oil.
"Always"....Mobil 1
Current fill: AFE 0w30
