I replaced my ICM when I removed the coil I dropped one of the two screws, I put it back together with just the one screw which is on the side of the male terminals, coil still loose, tried to get screw from local home depot no luck. Question Is it safe to drive car this way till I locate a other ignition screw ? Thanks
