OVERKILL
$100 Site Donor 2021
Originally Posted By: grampi
As far as the amp goes, each VC will only be getting 215 watts....though the amp is capable of producing a lot more power than that, voice coil impedances and load requirements for the amp prohibits connecting it in such a way that would unleash all of that power...so the amp will have easy duty...and my AVR already has a low pass filter on the LFE output set at 80 hz (I'm sure most AVRs have them)...I'm not sure what the roll of rate is, but it's probably at least 12 db per octave...the amp has one too, I can use either one I choose...
If we are talking about the Crown unit, you can run it bridged mono @ 4ohms based on the spec sheet.
You can only wire it up three ways:
1. Stereo: Each voice coil fed separately from the amp, 8ohm load
2. Mono parallel: Positive and negative posts on each coil are bridged with a single feed back to the amp from each bridge. 4ohm load
3. Mono series: Positive on VC1 into negative on VC2, negative from VC1 into the amp, positive from VC2 into the amp. 16ohm load
Each configuration gives you a different amount of peak power. Personally, I'd go with the 4ohm bridged configuration. If you are using an amp that will drive a 4ohm load bridged, why not take advantage of that?
