Recently this car ( 2000 Honda CRV w/210k mi) stalled and would not start again (hot or cold). There is no spark. #9 ignition fuse is ok . No CEL codes. Fuel pump runs a few secs. I wanted to pull the dist rotor to check the coil and igniter (icm) but the screw head is stripped. Before I deal with that, could simply I check the ignition / cps at the gray 8 pin connector at the distributor? All that I can find on the web so far is that the black and yellow wire is the power in to the distributor. All I'm really trying to find out is whether the problem is the distributor is bad (vs which component inside - igniter, coil, hall effect sensor, etc) as aftermarket distributors for this car are relative inexpensive. Advice appreciated.
