JHZR2
Staff member
Originally Posted By: KlooksKleek
Thank you to all. I've read and appreciated all responses.
The dirty deed (literally!) is done. Rotella T6 is now in the engine and let's hope it will help at least a bit in terms of a cold start. We got it running today in 24F degree temps but the machine was not happy to do so. Seemed to crank decently but took several tries to get it to catch. Fuel is fresh and from a local place, so I'm sure it is blended for winter and not a problem. Regardless, we threw in some Power Service anti-gel and filled the tank. Gave the car a 8-mile run before the oil/filter change and an 8-mile run after.
It's a dirty burner, for sure, and honestly I'm not much of a fan having now experienced the car up close. It looks and seems pretty worn, although it's got a really great, classic appearance. Having owned a 2000 TDI of 1.9 liters, this 1981 2.4-liter 240D is an entirely different animal and not a very admirable one in its present state. It's got hard-core diesel exhaust odor, probably doesn't have a single item of pollution control, and the owner says he's got to add oil more than just infrequently (no leaks, he says). With the T6, I guess he'll probably need to start adding even more, and to prepare for leaks, too. We'll see. But what can you do, it's flippin' winter time in Chicago.
Yes they are a different animal than newer diesels. That said, what was the condition of the battery? What were the starting parameters? How does the owner run the glow plugs (they stay on longer than the light and you can hear the relay click off, you can also glow multiple times)? The 81 model may have loop type plugs which run in series and can be upgraded. What is the throttle position for starting cold? Idle adjustment?
When were the valves done last?
Oil consumption concerns me. Neither of my current w123s burn a drop of oil. It amazed me when driving me 82 300cd cross country!
