Hi, our '05 Envoy 4.2L will often indicate low (no actually) oil pressure at hot idle. This started a couple years ago and I changed the oil pressure switch. That took care of the problem until recently when it cropped up again. Generally, dropping it into neutral will raise the rpm enough to make it read pressure or I can just give it a little gas while my foot is on the brake pedal.
For those who don't know the oil pressure gauge just displays a calculated amount based on rpm, temperature and I don't know what else. The pressure switch just tells the computer it's okay to calculate a pressure.
I'm away from the thing now but intend to hook up an analog gauge to the test port on the filter housing in the next couple of weeks. If I find the pressure is dropping below the 7 or so psi switch setpoint I'd like to try a heavier oil to raise the hot pressure.
Okay, after all that my question is this: Would their be any detrimental effects to running a gas rated 15W40 in place of the 5W30 I've been using in this 135,000 mile vehicle? I don't intend to keep it more than another 9-12 months so an oil pump is out of the question. If the analog gauge shows adequate pressure at idle I'll just replace the switch again.
