Sounds high to me but may be the norm in your area.
You could always go to Wally or China Freight and buy a plug kit for a few bucks and DIY it.
A plug will either work or it won't in my experience. If it does it'll be fine for the remaining life of the tire. If it doesn't, you can always have a pull-through mushroom installed from the inside.
I've plugged tires myself and have also had shops do so. While the proper repair is a pull-through mushroom, a plug will typically work just fine through the remaining life of any tubeless tire.
