Inside The BITOG Bachelor's Bedroom
Truthfully looked through the bachelor OP's photos anticipating the hanging limited edition BITOG calendar with each month showing opened used oil filters with wavy pleats and holes in the private areas.
Looks like a garage conversion, down to the oil stained carpet.
Hope one never needs a fire dept. Locals went running when they saw a practice 155 holding the front door open at my home.
Where is the oil porn?
Im expecting a photo album showing under valve cover pics and oil fill gloryholes.
What is in the mason jars? is that Mobil 2?
The mason jar on the nightstand is filled with SJ rated green Kendall GT-1, the other two are SN QS conventional 5W-30 and 76 semi synthetic 5W-30. The latter two I poured up to do a cold flow experiment, the Kendall I poured up just to look at it.
Originally Posted By: Recalculating
Originally Posted By: JHZR2
Not understanding the mason jars filled with random fluid.
Cologne for anticipated date with an oil change?
Looks like brewed sweet tea for when he gets thirsty in the middle of the night.
Originally Posted By: Mr Nice
Should keep all that oil in your garage. Girlfriend probably doesn't like motor oil inside your room.
Maybe it's personal lube.
"oil fill gloryholes" - now that's kinda funny!
Is the OP a bachelor by choice, has just not found the right women yet?
If you bring women back to your house they will not be impressed with your oil collection, in fact might might run at the sight.
The QS oil cans were from around 1970 if I remember my Dad would buy by the case.
