Hi all, here is my UOA from my spring/summer run. I usually stick with 5k mile oil changes ( I dont drive much and get antsy..) This analysis was courtesy of Pennzoil, so thanks Pennz
I only wish that I could of obtained a TBN number for this oil, but based on the lack of anything bad seen, I assume this could of stayed in quite a bit longer..
By the way, the filter used was a Napa Proselect, in which I also cut open.. I was going to try to get a measurement of surface area of filter element but forgot to..
The ADBV was a bit stiff, oil was in about 6 months. I suppose the only thing I dont like about this filter is the ADBV, so next time, I might go with a Napa Silver, which I believe has the silicone ADBV, someone please correct me if im wrong. Thanks
