Originally Posted By: Shannow
While a thicker oil will generate more heat due to internal friction, it will typically always have a higher minimum oil thickness than a thinner in any sort of reasonable engine oil viscosity.
It won't MAKE it overheat, MAY provide more reserve, but overheating is not a proposition that allows long term operation on any oil.
You don't have any issues in Utah and Nevada by the sounds of it.
+1 While thinner oils may create less heat through friction, it is still better to run a thicker oil if you have an engine that is running hotter than usual especially at track days and thing like that, te new Corvette Z05 recomends 5W-30 for normal driving , but Mobil 1 15W-50 when being used on the track and being driven hard.
