Quote:
Quote:
I get 5% off fuel purchases with my Sam's Club MasterCard, and I'll max out the fuel rebate most likely. I think it's on the first $6k in fuel purchases, FWIW.
Costco has the identical deal (probably copied it from Sam's). I rejected the card though because the points can ONLY be used in Costco, and I don't spend that much money there.
- Civic Hybrid goes from 50mpg to 70mpg if I slow to 55.
- The Prius I rented went from 45mpg to 65mpg when I slowed to 55.
The key is the DRAG which decreases approximately 40% when you slowdown.
Costco's old Amex was 3% gas/max $1000 qtr, 2% restaurants/travel, 1% other. Hit the gas max on 10K mi. trip. Now it's Visa with 4% gas/max $1750 qtr(7000), would have covered the trip, 3% restaurants/travel, 2% Costco, 1% other. You have always been able to cash out the annual rebate at the store. $500 a yr avg here. Also have a 2% grocery card and 1.5% all else card, all no fee.
50-55 mph is probably the sweet spot for min top gear speed / max lower drag speed. Many new cars have instantaneous mpg displays to verify when cruising. When I towed a 4x8x2' box trailer behind a BMW E30, it was like dragging a parachute at anything over 55. Should have airfoiled the front surface like semis/trailers do. Most cars are pretty aerodynamic now though. But my sweetest hwy cruising for getting there is at least 10-15 over.
