I haven't posted here in a couple of years. When I was last active, I was using MoS2 in my '95 Miata. I noticed smoother running, potentially better fuel economy, and measured lower sound decibel readings at idle.
Soon after dropping from this forum, I noticed that there was a kind of sandy grit in the bottom of my oil change bin that drained out with every change. This is a daily driver that gets about 1000 miles a month, and gets an oil change about every 3500 miles with a full synthetic oil.
I then popped back on the forum and read a thread where someone seemed to have the same experience after using MoS2. So with the next oil change, I didn't use any MoS2 and there was no grit when I drained that oil. The following oil change, I put the MoS2 back in at full quantity, and the grit came back with the following oil drain. I haven't used any MoS2 since then, and there has not been any of that sandy grit since.
Not sure why it seemed to precipitate out these sand-like particles. The car gets driven at least six days out of seven so it rarely sits. I'd be curious to know if anyone else has experienced this.
Thanks.
Thanks.
