As the subject says I need some help!
I drive a Renault Laguna 1.9dci 2004 with 220k kms in it! Always changing oil at 10000km,as the winter came I noticed that the engine is working louder at start up and the oil needs more than one minute to get everywher (engine noise decreses) the oil what is in the car has 6500km on it. I use recomended Elf (Brand of Total) 900sxr 5w-40! Owner manual stats that the oil needs to be Acea A3/B4, plus the factor of winter conditions -20C = 0w-xx,-15C = 5w-xx and -10C=10w-xx.
My thoughts are the oil is not working as it shoud be so I am thinking about to change it,so here is the place where i need the advice which oil to use!
Listed some oils what i consider to be better and thinking about it to buy:
Liqui Moly 5w-40 Diesel Tech
Liqui Moly 5w-40 Diesel Syntoil
Ravenol HDS 5w-30 this oil is Acea C3- but the 2005 model uses this one
Elf Evolution 900SXR 5w-30
Andi have to thanks the site to letting me be here!!
