Ryan, my 2014 XV Crosstrek 5spd did the same thing with the high idle hang between gears or in neutral when rolling.
I believe with any E-throttle vehicle, automatic or manual, you'll find this high idle situation in neutral or between gears (depending on the trans) only when the vehicle is in motion. If no ground speed is detected, it will instantly idle down once warm.
Are you digging this 6spd overall? I still haven't driven my SILs.
