I've recently upgraded from Baldwin BT223 to Baldwin B178 for more filtering on my 2TR-FE engine. They have the same size on o-ring gasket and outer diameter. I'm now planning on replacing it with Baldwin B2-HPG and my question is, will if fit or won't leak? Because the outer diameter is larger than the BT223 and B178 but they have the same o-ring gasket size. The length of the filter is not an issue.
Thanks
Thanks
