Originally Posted By: Kira
I do.
We're lucky with the H7 lamp. The blades fit perfectly into the appropriately sized female "blade connector" commonly found in solderless connector kits.
In fact, that's what was in the cheap plastic plug which burnt away. You could've crimped the female down and eliminated the buzz which raised the resistance through the roof.
My neighbor watched with interest when I crushed away the flimsy plastic, squeezed the connector down a bit, added a dab of dielectric grease and replugged his GF's lights. He hasn't had a blown out bulb since.
Inspect your terminals. The connectors might respond to what I described if they're not too brittle.
Remember, the H7's prongs stick straight out and the wires won't touch at all. Kira
You're a genius.
I ended up making a temporary fix with a blade connector I had laying around. Not the most ideal repair, but it'll work for now and gives her 2 headlights again.
