- Joined
- Jul 2, 2007
- Messages
- 5,294
On August 13, 2013 I bought a new 85 month genuine Subaru battery for the Forester and let the Subaru dealer install it since the car was in for an unrelated TSB issue at the time. Had a 25% off coupon for OEM Subaru battery and free install, made the cost slightly less than a parts store battery.
I think it's developed some battery gas leakage because the (+)terminal keeps having that white-green powder build up. This past summer was first it did it and I cleaned it up with a fine wire brush, finished with spray-on foaming battery terminal cleaner.
Noticed slightly slower than normal cranking recently, checked and sure enough the residue build-up has started again.
My question is, will this be covered by the pro-rated warranty, i.e. is the gas leakage that causes this considered a defect/failure or is it considered "normal wear and tear"?
This is month #40 out of 85 on the warranty.
