Originally Posted By: BrocLuno
Originally Posted By: UltrafanUK
I've got no interest in wanting to block the oil filter, so will follow the recommended half OCI limits. If the relief valve in the oil filter fails after it blocks, it can blow the can apart during a cold start if you do not use German steel.
The same half OCI advice also applies to using a high detergent FS oil to clean up a sludge monster. It's one of the reason the Iffybrakecrashlube shops keep saying 3000 mile OCI's are best, which they are not.
Oh please, there are two relief valves in all GM engines. One internal to the oil filter that just by-passes the media and one internal for the pump or filter base. No one has "blown a can" in a USA engine in 40 years. Yeah, some racers have because they block all the reliefs and they are spinning big RPM with heavy oils. But not on a run of the mill street engine. Get real ...
Integral pressure relief valves are not used in many modern engines because they are not reliable. If the engine suffers from varnish or sludge the valve sticks. Better to use a more expensive oil filter with it's own valve.
