Among the Pentosin items on CLEARANCE at my local AZ is this low viscosity, full synthetic ATF.
It states on the bottle:
"Pentosin ATF 1 LV is a high performance ATF based on high quality HC synthesis base oils for lifetime application in automatic vehicle transmissions.. It can be used wherever 'low viscosity' ATF is required."
Would you assume this product to be good for Dexron VI and Mercon LV applications?
