Originally Posted By: nthach
Originally Posted By: ecotourist
I had problems with the traction control and ABS systems on my BMW. My specialist repair place wanted big bucks (far more than $1200) to replace an electronic module. But I found a shop that rebuilt my old module (with a 5 year guarantee) for $300 and I removed and reinstalled it myself in less than 10 minutes. So there is hope.
That said, I do think simpler is better.
Be careful - a lot of rebuilders don't use quality electronic components like low-ESR/long life capacitors and auto-spec transistors(triacs, MOSFETs, drivers, etc). Caveat emptor.
No doubt you are correct. But this rebuild is guaranteed for 5 years. And I don't think anyone with any sense would rebuild with inferior parts and then offer a 5 year guarantee.
And if they used old parts, all the better. I'd expect old electronic components to be as reliable as (or maybe even more reliable than) new ones. When does electronic equipment fail? - the highest rate of failure is generally in the first few months.
