Originally Posted By: NycDito
So i went to check the residue and it is in fact some sort of very fine substance, oily. Feels different than motor oil. Then i decided to rub my finger under the actual cover in the oil filler hole area. Under the cover near the hole (not visible).. and below is what i see. Maybe there's a crank case ventilation issue? I might just have to overhaul the CCV and replace valve cover to keep peace of mind.....Greeeat
This reminded me of rust..kind of gritty..
and here is where i rubbed the white residue...
Maybe there was an underlying issue with previous owner, or it developed under my ownership. Or maybe its normal and im being too picky. Maybe over time, it'll clean up.
Was the white residue gritty ??
Looking at these pictures again, I suspect your car has some light varnish that the flush has started to gently move.
The shiny white stuff may not be an inorganic precipitation like I first thought. It may be a shiny clearish surface on the oil / varnish that acts like a mirror and appears white. I've seen this before (in chemistry, not an engine).
You are also using regular fuel additives, this can also find it's way into the oil. So you now have a mix of oil flush, oil additives and fuel additives all mixed up.
My advice: stop spending money on all these extras. Just run it on good oil and good fuel for a bit and see how it goes. Like they say, a few short OCI is a gentle way to clean up an engine.
