I'm working on a Troy Built wood chipper and vac that isn't pulling fuel. I pulled the fuel supply diaphragm off and disassembled it to inspect the rubber and spring within, and while they are in good shape, there is a decent amount of oil inside the assembly. Will excessive oil intrusion cause the diaphragm to not pull fuel?
I can get the engine to run with some starting fluid, but its not getting gas to the carburetor. Yes it has gas in it.
