The 2500 weighs about 7,500 lbs empty, not towing, but climbing and descending grades up to 14% daily.
I'll go up in 4x4, but not downhill especially on the exhaust brake,
because if the front tires lock up on ice, there is no way to steer the vehicle.
I did both ends and the transfer case on both vehicles just over 100k kms.
The diff fluid on the 2500 was as expected, but I should have done the transfer case at half time, or about 50k kms.
The FF is Dexron VI, which seems light to me. I used up the last of my Petro-Canada Dura-Drive instead, 1.5L.
On the 1500, the rear diff, no 3/8 drive drain plug so I had to syphon the fluid out, looked ok, as did the transfer case fluid.
But the front diff was a disaster.
Investigating the various GL-5 lubes reveals a large discrepancy from one brand to the next.
For example, if the Mobil 75w140 was any thinner, it would be a thick 75w110.
(SAE GL 110 is a relatively new grade. I'm surprised that 75W110 and 80w110s are not commonplace, especially for commercial transportation looking for fuel economy over the popular GL 140s.)
If Pet-Can's 75w90 was much thicker, it would be a thin 75w110, and so on.
And, if gear lubes are anything like engine oil, they lose their W rating over time and service.
I think the chart for gear oil grades is SAE J306.
SAE GL 80W is good down to -26C, not good enough. I need -35C or very close to it.
Synthetics are typically more forgiving as the temperature drops out of grade, and should stay fluid/colder than conventional.
I'm not concerned about getting the last tenth % of fuel economy, and looking at "thin" synthetic 80w140s for a new "go to" grade.
Any thoughts?
