john_pifer
Thread starter
Originally Posted By: Astro14
Well....you can put me in that "Ted Nugent/eccentric" category.
I am a big 10mm fan.
My G20 with full power loads (like Buffalo Bore) is very controllable. I've shot .357 revolvers that are far worse, and a 4" .41 Magnum (my brother's model 57) is far worse. My brother's Dan Wesson 10mm is also very controllable. A bit more bark than a 1911 in .45 but nothing like that Model 57.
Now. the Glock is big, and it takes reasonably big hands to get a good grip and reasonably strong hands for managing the recoil, so, no, it's not a good choice for many shooters, and that probably excludes quite a bit of the population.
In my hands, however, follow up shots are quick, as quick as with a .40 compact, or a 9mm compact, though not as quick as a 9mm full size service pistol (like a Beretta 92). I bought the G20 just because I wanted a 10mm. 220g hard cast for bear country, 180g JHP for SD. A very effective pistol with great ballistic performance. 15+1 rounds of very effective performance. It's close to .41 Magnum performance but far, far easier to shoot and holds nearly 3 times the ammo.
It's a great gun.
But, I'll admit, not great for everyone...
Agree with everything you've said here.
If I could only keep 1 handgun, it would be my G20. Why? It's the most versatile handgun I own. I can run 135-grain hollowpoints for home defense, to prevent overpenetration, or 1300 FPS 180-grain loads, or heavy solid bullets for carrying in the mountains. Or I can run .40 S&W for cheap range practice (which I do often with zero issues).
It does have a large grip, and needs a firm hand and good technique to tame. For those who are willing to put in the time at the range, it's not a problem at all.
Heck, I even carry mine IWB from time to time. Not bad at all.
Here are some Underwood-loaded Gold Dots I shot into some heavy plastic agricultural water jugs (like what's used on farms).
Really fun handgun. I've owned mine since 2001. It was actually my first handgun.
It's a great gun.
