Originally Posted By: KL31
Originally Posted By: 09_GXP
Spec is 5w30 with Ford certification.
Yes and oil is now a 5w20. So that doesn't really comply with their specs for the car. I'd buy some 5w30 and 0w40. Keep receipt for 5w30 and use the 40. When it shears to 30 and you have a receipt for 30, how will Ford refuse any potential warranty related issues?
The spec is for new oil. Ford does not have a spec for used oil so we can't say that the oil in the sample violates anything. A lot of people get nervous when oil shears down from 30wt to 20wt but this is not in itself cause for concern. #1. The oil weight grading system is just that a system, there is not something magic that happens at the cutoff line. #2. It is highly likely (almost guaranteed) that the same oil conditions were seen in testing or at the very least assumed during design calculations.
As CT8 pointed out Ford would still have to prove a non-recommended oil caused the failure but something here is happening beyond just the oil.
