Can't believe I fixed it
by Stelth
02/25/18 04:40 PM
Cruise Control Set at 55
by das_peikko
02/25/18 04:39 PM
Who here has satellite radio in your vehicle?
by ZZman
02/25/18 04:01 PM
Oil choice for new to me 07 escape V6
by gabriel9766
02/25/18 03:10 PM
Super cleaning windshield
by mclasser
02/25/18 02:36 PM
New WM oil filters...
by rollinpete
02/25/18 01:49 PM
Swapped Out Bunch of Indoor Flood Bulbs to LED ...
by LoneRanger
02/25/18 01:45 PM
Scanner ABS Transmission and Engine Codes reader.
by littleant
02/25/18 01:38 PM
Meijer - Quaker State buy one, get one 50% off
by Bighorn2500
02/25/18 12:50 PM
Anyone own a 3rd generation Toyota Tacoma
by 007
02/25/18 12:47 PM
Best "wax as you dry" type spray wax?
by aquariuscsm
02/25/18 12:39 PM
Any current Edge 0W20 users here ?
by aquariuscsm
02/25/18 12:27 PM
Which one?
by RogerBacon
02/25/18 12:25 PM
VW Polo, 1.4 TSI 150hp (ea211) 0w-30. 11700km
by VTS16
02/25/18 12:16 PM
Atlanta Quick Trip 500
by bdcardinal
02/25/18 11:58 AM
Gumout One N Done vs All In One
by Patman
02/25/18 11:44 AM
ACEA A5/B5 vs ACEA A3/B4 for Volvo V60 Polestar?
by A1ex
02/25/18 11:36 AM
Vogue Signature V tire review
by 2strokeNorthstar
02/25/18 11:33 AM
Which have improved faster - engines or oils?
by HawkeyeScott
02/25/18 11:12 AM
PP 5W20 bottom of jug debris
by aquariuscsm
02/25/18 11:05 AM
A1ex, Grozd, swc, coronad0, davidsain
64288 Registered Users
91 registered (08versa, 901Memphis, andrewp1998, A1ex, AnonOIl, 2015_PSD, 5 invisible), 1817 Guests and 94 Spiders online.
64288 Members
65 Forums
278790 Topics
Page 1 of 2 1 2 >
#4267023 - 12/05/16 04:21 PM 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6
Audios Online   content
Loc: Lyndhurst NJ
http://imgur.com/OB2VA0i
Only thoughts would be the thickening and sooty sample would be from the performance nozzles I installed 2 years ago. Any thoughts on anything else? Thanks.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2005 BMW M3 Liqui Moly 10/60
1997 John Deere Gator 4x2
2007 Mercedes GL320 CDI -Programa/Malone Tunes
#4267039 - 12/05/16 04:40 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Audios]
UltrafanUK Offline
Loc: England
Yep the oil has thickened and the Iron is a tad high.
I would cut the OCI to 3000 miles and make sure the block is not sludged up. The increased viscosity has nothing to do with the injectors.
Shell Ultra 0 or 5w40 or Liqui Moly 5w40 plus Ceratec every long OCI.
LM idle flush every 100K km.
#4267059 - 12/05/16 05:03 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Audios]
Kamele0N Online   sick
Loc: Slovenia
Use apropriate VW 505.01 or VW 507 oil otherwise....
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3851944/294k_KM_on_2006_TDI_(BEW)..._s#Post3851944_________________________
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4267064 - 12/05/16 05:05 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Audios]
LeakySeals Offline
Loc: Hudson, NH
wonder how M1 0w40 would fare
06 Escalade 6.0L AWD 155k. M1 EP 5w30 Fram TG
03 Maxima 3.5L Unknown miles ST 10w30
#4267076 - 12/05/16 05:28 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Kamele0N]
Loc: Lyndhurst NJ
This isn't a PD motor, its the earlier ALH, no crazy specific oil needed for this as long as its diesel rated.
#4267077 - 12/05/16 05:29 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: UltrafanUK]
Loc: Lyndhurst NJ
The block seemed pretty clean, just had the oil pan off when resealing it at 180k. My interval has been 5k since i bought it at 150k.
#4267209 - 12/05/16 07:40 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Audios]
2004tdigls Offline
Loc: maple ridge, bc
delete the egr(if you have not already) diesel egr dumps huge amounts of soot into the oil( which increases wear)
you can try the vag com mod
http://www.ross-tech.com/vag-com/cars/tdi.html
or purchase an ecu flash
#4267236 - 12/05/16 08:08 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: 2004tdigls]
Loc: Lyndhurst NJ
Ive been looking into this all night, going to start there tomorrow. We are heavily sooting out the tailpipe since the injectors, they're the .216 nozzles. Even though I cleaned the manifold at 150k, Im wondering if its starting to clog already.
#4267239 - 12/05/16 08:11 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Audios]
2004tdigls Offline
at least do the vag com mod, this will drastically slow down the egr clogging
and ask for help here, a wealth of information:
http://www.tdiclub.com/
Edited by 2004tdigls (12/05/16 08:13 PM)
#4267423 - 12/05/16 11:59 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: 2004tdigls]
UltrafanUK Offline
Loc: England
Don't delete the EGR as it's an anti social act that often invalidates the hull loss part of an insurance policy if it is not declared as an engine mod. In some states and the EU removing emissions gear is a criminal act and even partly invalidating an insurance policy makes you liable for an accident even if it was not your fault. The main get out clause used is that the vehicle was not described correctly in the application or renewal.
It will make no difference to the Fe per mile number. I would first of all check the oil pressure and temperature are correct, as the other wear metals were OK and oneof the few parts that causes Fe only to increase when worn is the oil pump. Driver style also makes a big difference and can double the figures, but that seems less likely.
If you see an upwards trend in the next UOA, try half a can of Liqui Moly Ceratec every OCI and just do an oil only dump every 3000 miles with the filter included every 9K.
If you read the silly link it starts by saying we are not responsible for any problems that arrise from following their instructions. Removing an EGR often results in a check engine light and confuses the ECU in warm up terms, often resulting in worse UOA results due to a longer warm up time, as the EGR can't heat up the incoming air.
SOOT in the oil does not cause extra wear as Carbon is a fairly good lubricant, all it does is slightly reduce the OCI limits, although that is allowed for in the OEM max recommended limit. Do make sure that the intake and EGR are cleaned every cam belt service interval, otherwise it can start to cause a post shutdown run on for a few seconds (Fouled intake) or lag when booted (Blocked EGR).
Edited by UltrafanUK (12/06/16 12:11 AM)
#4267483 - 12/06/16 04:20 AM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Audios]
rooflessVW Offline
Loc: North Carolina
UltraFanUK post:
Don't touch emissions - check
Insurance B.S. - check
Ceratec - check
Give it a rest, man. No one cares.
"Zed's dead baby, Zed's dead."
#4267528 - 12/06/16 06:50 AM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: 2004tdigls]
Loc: Lyndhurst NJ
Im going to code it today, do you know a good median number to input so I don't get a check engine but reduce some of the EGR?
#4267602 - 12/06/16 08:19 AM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Audios]
2004tdigls Offline
Special adaptations: Login code 12233:
These procedures do NOT apply to the PD engines, which use a completely different type of EGR system and for which there is no known modification. !
To perform the following adaptations (except idle) you need to use the Login function.
Enter 12233 as a Login code.
Misuse of some of the adaptations can lead to engine failure.
This is done at your own risk!
Note that the EGR setting is for off-road use only...
[Select]
[01 - Engine]
[Login - 11]
Enter 12233 to activate special adaptations,
[Do It!]
[Adaptation - 10]
Enter the "channel number" below to select each channel.
Put in the suggested value(s) in "new value".
[Test]
Observe the "test value" field to make sure the adaptation setting is acceptable.
[Save]
Channel 1: injected quantity
Check the injected quantity at idle, engine warm and all power consuming devices turned off.
Specification is 2.5 to 9 mg/h.
To change the amount of injected fuel perceived by the ECU, go to adaptation channel 1.
If you have driveability problems, you may want to increase it to 3-4 mg/h.
For slightly improved throttle response, you may try to decrease the value.
Channel 2: idle speed
No login required
The stock adaptation value should be 32768 (corresponds to 903 rpm).
Increase or decrease this to change idle speed.
Channel 3: EGR
To decrease the EGR rate, increase the number to the highest possible value (typically 33768).
This will prevent/slow down the intake manifold clogging problem and reduce smoke.
Though the MAF at idle is still within specifications (370 mg/h) do not use this adaptation on the road :-)
Again, this EGR setting is for off-road use only !
#4267628 - 12/06/16 08:31 AM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: UltrafanUK]
2004tdigls Offline
simply NOT TRUE, this paper proves otherwise.
http://www.sciencedirect.com/science/article/pii/S1110016812000907
Increased soot level causes considerable increase in the carbon deposits and wear of the various vital engine parts such as cylinder liner, piston rings, valve train and bearings. Wear of the materials also increase due to chemical reactions taking place on the surface (adsorption and corrosion) or due to abrasion of material or rupture of anti-wear film by soot.
Edited by 2004tdigls (12/06/16 08:46 AM)
#4269807 - 12/08/16 05:28 PM Re: 02 Golf TDI, 185k on motor, 5200 mi on Rotella T6 [Re: Audios]
Loc: Lyndhurst NJ
Thanks for the help 04tdi, I knocked the egr down and its amazing how little soot comes out the tailpipe now. Feels peppier too! Im going to resample in 5k and see how things look.
Edited by Audios (12/08/16 05:28 PM)
Page 1 of 2 1 2 >
