I have a 7.3l Diesel in a Ford pickup. The high frequency vibrations from the Diesel combustion can cause coolant cavitation which in turn can cause cylinder wall erosion. Worst case it eventually eats all the way through the cylinder wall. Ford and other manufacturers recommend a Supplemental Coolant Additive that protects against cylnder wall erosion. I believe that these SCA's protect by forming a sacrificial coating, i.e., the coating is eroded instead of the cylinder wall.
The manufacturers of RMI-25 recommend it as an SCA for Diesels and claim on their website that their product contains an oxygen scavenger to prevent cavitation. It evidently is supposed to prevent cavitation altogether, not just protect against the effects of cavitation like other products. I'm not a chemist, can someone explain how an oxygen scavenger prevents cavitation?
RMI-25 seems to have a good reputation and I don't doubt that it's an effective cooling system cleaner. What I don't want to do is find out the hard way that it's not an effective cavitation preventer.
Thanks,
Bob
Thanks,
Bob
