The transmission has a breather that let unfiltered air to circulate inside even sitting, as climate temperature changes. It may get some dirt, depending on the environment. I've change a 8 years synthetic oil on a 4hp20, with low miles and found a little abrasive material (dustsand) on it, but the oil was clear as new. I changed it out. See if your breather has a good filter, mine didn't, just a cap. Humidity is another issue...
