I've boon looking for the ultimate low temp grease for my snowmobile idler wheel bearings and chassis lube. I know it says not four wheel bearings, but I believe that's due to the high temps of bearings with brakes. My bearings should never be much above ambient temp. Temps are almost always going to be below freezing, sometimes -40 or colder. Needs good water washout, low torque, long life, good corrosion. I think I've settled on Aeroshell 33, I like everything but the $20 a tube local price. Sure I'm not going to be using much of it, but I think the aviation name and requirements are driving up the price. Anybody know of a comparable grease, at a lower cost? Or a better grease you recommend?
Thank you
Some good reading on this product, and a nice test on grasses done by the Army.
http://files.ua.prom.st/30770_asg33.pdf
http://www.shell.com/business-customers/aviation/aeroshell/aeroshell-greases/grease-33.html
http://www.dtic.mil/get-tr-doc/pdf?AD=ADA450746
Thank you
