Originally Posted By: Rolla07
Originally Posted By: FZ1
Originally Posted By: igs
Originally Posted By: Tony10s
Just like there are people who are "afraid" or reluctant to use a 0W-20 or 5W-20 motor oil when the oil cap and manual say to do so.
Do the oil cap and manual say so because it's better for the car or because they are required to?
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=14177&flag=1
This post,by IGS,solves the mystery of the thick/thin debate. It's all about the EPA and Cafe. The manufacturer is required to enter on the oil cap and in mfg. literature the same grade oil that the mfg. used in the EPA testing. That's why some new cars(Hondas)are burning oil. The Mfg. spec oil is not best for the motor....it was best for the epa mpg testing ....and the Mfg. is required to spec that oil grade(the grade used for the epa test) on the oil cap and in the Manual. Thank you igs. Now I know why my new Hondas burn a little on 0w-20.
So I guess since you must obey the warranty by using 0w20 in cars that the mfr would only stamp 0w20 if the penalty from CAFE was more than the impact of all the oil related issues they would encounter under warranty... so I suppose 0w20 causes fewer issues (less in auto mfr repairs) that it is worth complying with the CAFE rules.
I'm sure the Honda engineers know that their motor will last 100k running any kind of oil and that their powertrain warranty is only 60k. Noticed you changed the weight of oil in your footer from 40 weight to 20 weight......Canada,you know.
