Hoping to get some advice from the crowd here about my situation:
Make/Model: Buick Century
Year: 2003
Mileage: 143K
Issue: Bought car used (third owner - no crashes or major engine work) with oil / filter changed in July 2016. Engine was intermittently heating (twice redlined for 1 minute but would quickly cool back to normal this past mid week.) Drove car 68miles on HWY and on way back later in the week and heard a knock and began feeling recoil in engine with CEL turned on - was able to drive home approximately 50 miles.
CEL checked with P0302 code (cylinder 2 misfire.) Had spark plug checked and coils and seemed to be fine. Wet compression test on that cylinder showed 66psi that rose to 105ish. No leak down test performed. Other cylinders with 125+ PSI. Car was diagnosed to have worn rings and I put in engine RESTORE with improvement in recoil during idle. Car overall drives smooth with expected loss of acceleration time.
I don't have the $$ as a I work for free to help veterans at my local hospital and barely saved to have this car to get to & from work (approximately 15 miles each way.)
Any recommendations from the crowd on what I can do to keep the car running for another 7 months or so (mainly for commuting.) The CEL continues to blink and was wondering what kind of damage I could expect to the catalytic converter? Do you guys think I could keep doing oil changes with Lucas Oil Stabilizer & Engine RESTORE every 30000 miles to prevent the engine from going down? Should I disconnect my fuel injector to prevent further blow-by? Do you guys think I can ride the car out for the 7 or so months I am looking to get out of it?
Thank you in advance! [:/][:/][:/]
Year: 2003
Mileage: 143K
