I replaced a pump but disturbing the hose caused the Infamous ford hidden O-ring leak. The stop leak may have masked that too, or just loosing the fitting after 22 years could have damaged the O-ring. There is no repair for that O-ring.
The problem is there are two hoses - I have no problem replacing the pump hose but it joins to another hose that likely requires dropping the engine and exhaust to get to the rack.
This is the pump hose, the fitting where it meets the other hose on the left is a swivel(I believe so) with an internal O-ring, maybe I can turn that instead of the fitting on hose 2. If I damage the O-ring on hose 2, its game over though.
Second hose to the rack (can't even see the end it is so buried)
This below looks like a great idea but I'm concerned about rubber and ATF. I'm sure it will last a year or two, and the o-ring leak is very small even if it fails. The OEM hoses are almost joined this way!
Plan C? Lucas, but I hate to add that. I see why that industry is so big. I called two shops and they said that is exactly what we would do for a car that age, unless you want a 2K bill(who knows what else will break). The tech said he would have no qualms putting in if it was his car in this case. Probably one bottle would take care of it.
