Borrowed a friend's '89 E150 short van (300/C6) to pull a trailer about 1000 miles over the weekend and was really disappointed with how it was handling the 2,000-lb.-or-so trailer on the way out, so I checked and the air filter and plugs were toast. While replacing them last night a friend and I wound up cleaning the throttle body and replacing the gasket (handmade from sheet material) while we were at it - it runs much better now (probably gained 5-7 MPH at equal throttle position on flat ground) but it won't idle down to where it was before. Speed in gear is about 700 (only about 200 high IIRC) but in Park it's up around 1,500. Barring any vacuum leaks, is there anything but IAC function that could be at fault? Nothing except above mentioned parts/systems was tampered with. I'm sure my buddy soaked the IAC solenoid pretty good while cleaning the TB - the solenoid is less than a year old but may have succumbed to being drenched in carb. cleaner. Any input from somebody with more experience with Ford's speed-density systems?
