So i've been having a VERY small oil leak. I thought it was due to loose drain plug bolt or something simple, nothing serious a drop or 2 a day. I was going to look into when i get my oil change done.
Today i did the oil change and looked under there, oil pan and oil filter BONE dry. I notice my cross member a little coated in oil, and then i see it. Seepage from my front diff.
Around August of this year, i had my passenger axle replaced by a shop. Because i couldn't pop the axle out of the diff. Paid the shop, they did the work everything is good. I didn't think to put one and one together, the oil leak MIGHT of started happening after that. The leak isn't a huge one just slightly on the pass side of the front diff. So i'm thinking MAYBE the axle seal got damaged.
I dont even know what to do at this point, i just sprayed brakeclean and cleaned up what i could. Maybe it was leftover spillage from when they pulled the axle but never cleaned it up? I dont want to start pointing fingers, because i really dont know. Its a minor leak but i'll keep tabs on it.
What would you guys do? Its a small neighborhood shop, I've used them like 3 times. Wheel bearing, evap leaks, alignment and the CV axle. The car was bone dry when i did the oil change in March.
