For the Lincoln, which specs Green, every place I talked to said Prestone is fine and an improvement over Green.
I called Prestone and they said plenty of Ford dealers use it for all cars. They said the green is a 2-3 year and theirs is 5(or maybe a bit more). Other that that no difference.
Less and less stores stock the Green. I guess the motorcraft distributor has them.
I removed the stat on the bottom and almost all the coolant is out, ran some distilled water thru it and its clear now. Coolant looked clean and perfect, all metal surfaces looked like new inside. Had M/C green before, was in 3 years.
