2001 Silverado 5.3, 111,000 miles, 2WD regular cab short box. Driven in three Michigan winters (road salt, the gift that keeps on giving), otherwise in the South and arid West.
I got an SES light, code P0452, "Evaporative emission control system pressure sensor low input."
No fuel smell, no problems filling the tank, and no difference in how the truck runs.
Here's what I've tried so far:
1. Replaced the gas cap with the original, which I used for 2-3 years before the current locking cap. Cleared code but it came back on the next start.
2. Unplugged and re-plugged the fuel tank pressure sensor connector, mainly to see if I could access the sensor without pulling the bed or tank. Snugged the big filler tube hose clamps at the same time. Cleared code but it came back again.
I also jiggled all of the line connections I could reach and felt the lines for damage. This was basically a blind operation, since the lines are above the fuel tank.
I'm reading and clearing codes with the paid version of Torque on an Android tablet. It has options for EVAP and Fuel Tank Pressue gauges--I activated both, but only the EVAP gauge gets data. EVAP reads between 12 and 19 percent, whatever that means, when I check it.
What other troubleshooting can I do without a "real" scanner? Does the info above suggest an obvious repair?
Thanks in advance for your suggestions.
