Originally Posted By: itguy08
So there's no benefit at all?
Probably on race engines which 99.9% of people are not running.
Like I said, I went on and on with the guy selling the miracle cans. He claimed the PCV system of the EB 3.5 was defective and the can would cure all sorts of ills with the Ecoboosts. It would increase MPG, cure the condensation shudder, add HP, and eliminate the deposits. When pressed for data (before/after dyno runs), he had none (he owned a speed shop). When pressed he stated his shop vehicle with the EB had one on since day 1. When pressed for intake pics there were none. Lots of pics of OTHER carbone'ed up engines' valves and none of the EB 3.5. IOW no data to back up the claims.
I'm at 105k on the SHO and no can. Not huge mileage but according to the vendors my engine should be barely running by now. Still starts up immediately, runs like a scalded cat and idles buttery smooth and MPG's are consistent from day 1 (I have records) If I have deposits I don't care as there is little effect at all on the day to day operation of the engine. And all this on a diet of 5w20 to boot (the '10's spec'ed 5w20)
No data to back up claims? THE HORROR!
Where have you been? No data to back up claims is pretty much the rule, and applies to much more basic issues like thin versus thick oil, synthetic versus mineral, etc, etc.
In the absence of data you have to ask yourself what's intuitively reasonable.
Is it intuitively reasonable that a catch can can catch? I think it is.
This is not to say that a VENDORS claims should be accepted uncritically, but the fact that someone is selling something doesn't prove its snake oil.
Its a pretty simple device, so not hard to understand or to make.
I don't particularly need one, since I've not got a turbo, but I did have some tar in my carb when I stripped it and I might eventually get around to rigging something.
Like someone above said, can't hurt, unless you've got data to back up a claim that it can.
