Yes, I check the oil often, because it is so old, and I will be know what that means if I should see that. I took it out for around 1 hour now, including around 5 miles on the Interstate (between 55 & 60, mostly) - so far, the gauge stays where I want it. I am hoping with the very low usage it gets that I am good until 2018, when I will be retired and then I would take a shot at changing the head gasket (I have done 1 time before on an Opel - had to change the camshaft (worn down lobes, that was a shocker), and you had to take off the head to be able to remove the camshaft), but never on this model.
