- Joined
- Jul 2, 2007
- Messages
- 5,294
2015 Ford Fusion at work that came off travel car designation for last year, was rotated into the personal assignment fleet this week and now goes home with me all the time
Nice car, just under 39,000 on the odo. Weird thing though, when operating in normal mode the logic in the transmission seems to favor lugging the engine (four cyl base). It will hold it right at the ragged edge of lumpy lugging even if you slightly tip into the pedal, until you give it more foot. Not so in the "Sport" mode, where gear selection and holding at more reasonable rpm is much more to my liking. And then there's that upshift/downshift thumb switch on the knob which is kind of entertaining but in all reality the shifts aren't quick enough nor crisp enough... likely has to do with limitations of the setup: base engine and base trans with a bell/whistle added to try and simulate the attributes of a stronger setup than what it actually is. ... just a few bitoger induced observations.
