Originally Posted By: John_Conrad
That's a good deal. I have two sets and use them a lot. I put my Jeeps in 4L, take my foot off the brake and can go up on the 4 ramps with no effort at all. That makes checking the transfer case, differentials, or servicing the transmission very easy since the vehicle is up in the air, and level.
thanks demar:
my metal ones can slip sometimes on my cement garage floor, i may have finished floor too smoothly..hopefully the rhino's will not do this.
my work around for my metal ones was to place just outside my garage door entrance, where they would but against the concrete, unfortunatley i have to do work on the ground!
My garage floor is poured concrete, stained with concrete stain over 20 years ago, it is as smooth as glass. The ramps stay put, even when I use 4 of them at once.
