Common rail injectors seem to have a lower seal problem, I've done half a dozen Kia ones, and this week a couple of Toyota Hi Lux 1KD diesels. The lower seal leaks, pushing carbon deposits up past the O ring and into the cyl head. In the Kia the first thing to go after the pickup blocks is the turbo, the first one I did involved a turbo replacement. These are the ones out of a Hi Lux today, No2 was really stuck.
No4.
No2.
There is a 30 digit code for each injector that has to be entered into the ECU, I've done Mitsubishi ones using our MUT III, and maybe our Autel Maxidas could do it, but it won't recognise this vehicle. The owner doesn't want it recoded, and it seems to run pretty well. New injectors, injector pipes, all seals and a rocker cover gasket.
No4.
No2.
