Does anyone remember these? My 1988 Aries - 2 weeks ago, temp gauge shot way up, I pulled into a parking lot to cool, it dropped on its own, so I was able to make it home without overheating. I already had a new t-stat & outlet & gasket. The thing with that setup (2.5 L, also the 2.2's) is that the radiator is lower than the block. The t-stat housing is in the water box casting. There are 3 holes in it - top is bleed plug, side has a plug (on this engine), and the coolant temp sensor is the lowest hole. I sprayed lots of PB Blaster all over the plugs & left it for a week, but as I feared, I could not remove the proper bleed plug or the other one. Used 8 mm Allen socket & breaker bar, no luck, the hex hole rounded off. So I loosened the coolant temp sensor, and let some of the hot coolant spit out of it while the engine was running. I also parked it on ramps, so that the radiator would be higher than the engine and ran it until hot, with the cap off. So far, it seems good - temp gauge steady, and a bit lower than before, and I think the fan hardly goes on now.
A couple of things, asking for comment -
1. The hole in the water box for the coolant temp sensor is not at the high point of the water box - would that make it less effective in forcing out the trapped air?
2. Does parking it on ramps and raising the front of the car sound like it would work? I think it does.
3. I read another option for this - has anyone had to do this? - Drill a small (like 1/8 inch) hole through the new t-stat body, so that any trapped air will slip past and into the radiator and then go out into the overflow and be gone.
