harry j
Thread starter
continued from above;
It should decrease next time. Other than that, the results still look quite good. Most wear metals held fairly steady, though iron (which tracks with oil use) decreased some thanks to the shorter oil run. The oil itself was also in good shape. The particle count (old machine) was 16/15/13.
No fuel or coolant was found. Just check back to keep an eye on things.
[code:js][/code]
Aluminum---------------2-----------------------------4 (universal average based on 3,500 OCI)
Chromium---------------0------------------------------1
Iron-------------------17-----------------------------9
Copper-----------------5------------------------------3
Lead-------------------0------------------------------2
Tin--------------------1------------------------------1
Molybdenum-------------288----------------------------81
Nickel-----------------0------------------------------0
Manganese--------------0------------------------------0
Silver-----------------0------------------------------0
Titanium---------------0------------------------------0
Potassium--------------3------------------------------3
Boron------------------52-----------------------------49
Silicon----------------26-----------------------------11
Calcium----------------3386---------------------------2150
Magnesium--------------14-----------------------------140
Phosphorus-------------673----------------------------710
Zinc-------------------775----------------------------834
Barium-----------------0------------------------------0
[code:js][/code]
SUS Vicosity @ 210F----------------------60.8--------------------------57-67 (SHOULD BE)
cST @100C--------------------------------10.45-------------------------9.4-12.34
Flashpoint in F--------------------------430--------------------------->385
Fuel%------------------------------------0----------------------------- Antifreeze%------------------------------0------------------------------0
Water%-----------------------------------0------------------------------ Insolubles-------------------------------.03----------------------------
ISO oil cleanliness code 16/15/13;
>=2 microns---------------------1,111 particles
>=5-----------------------------411
>=10----------------------------113
>=15----------------------------44
>=25----------------------------10
>=50----------------------------1
>=100---------------------------0
I changed the oil pan gasket during this oil change, it will factor in the next OCI
[code:js][/code]
[code:js][/code]
