Thing is, with OIL HOLES in the center tube, you are guaranteed to get "flow performance". Even if there was a blank that did not clear.
However, louvers in the center tube, there has been some louvers that have NOT been punched out correctly, the holes are too small, and many of them.. A .1 mm smaller slit and you got restriction.
