This is great for maximum performance but what happens if one of the actuators sticks a valve open on grandmas 60K miles daily driver? the simplicity of a big mechanical spring still isn't such a bad idea.
Formula 1 cars have had pneumatic valves for awhile.
Near ideal valve lift and timing for any situation a passenger car engine might encounter seems like a leap forward as significant as variable ignition timing.
Yes, the mechanization must be fairly well understood as it's not a "new invention". Seems like I read a few years back that the F1 teams charge the pneumatics prior to the race (no parasitic engine driven pump) which, if true, means the system doesn't require huge amounts of pressure to the extent to need constant replenishment. And I have never heard that the valve system failed on this or that car. Interesting. Going only on memory there so YMMV.
Don't F1 engines use normal cams with gas springs instead of metal springs?
That's different from the system discussed here which appears to use electromagnets to open and close the valves.
I'm sorry I didn't see your original post. Yes, you're right, I looked further at it and the systems as they exist now are cam driven with pneumatic springs only. Renault has apparently been working on various means of actuation to include both electromechanical and even hybrid pneumatic/hydraulic systems. Seems everyone would like to do away with the rotational (and other) mass of the camshafts but it hasn't happened yet if what I read is correct.
