0/20 spec really?
Originally Posted By: Shannow
Originally Posted By: CharlieBauer
I don't think that oil can be sold as a 0w20.
It's either a 0w12 or a 0w16.
When I got the HTHS off Penrite, it was clearly a "16"...
What was the HTHS Shannow ?
Originally Posted By: SR5
Here is another 0W20 oil that isn't your typical ILSAC spec oil
Penrite 10-Tenths Racing 0W-20
100% PAO & Ester - fully Shear Free
API SL & MB 229.1
Zinc = 1760 ppm
Boron = 630 ppm
Moly = 100 ppm
Ca = 2960 ppm
TBN = 9.8
It's either a 0w12 or a 0w16, possibly both.
OK fair enough, I didn't look closely at the specs, and just took it at face value (the label).
It makes 20 grade according to the 1999 J300, but the revised 2009 J300 I have puts it as a 16 grade. Just as you say.
To be honest, I would use the Penrite 10-Tenths Racing 5W-30
KV100 = 10.0 cSt and HTHS = 3.34 cP
That's clearly in 30 grade territory.
That HTHS is quite nice, most ILSAC grades are 3.0 +/- 0.1, while HDEO or Euro grade A3/B4 or C3 oils in 30 grade are typically 3.5 to 3.6 cP. So this value of 3.34 nicely sits in the middle.
I should give it a run some day.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3030303
Thanks Mate.
Quote:
was always on the thin side of 20, but with the new J300 6.7 cst puts it in the 16 category.
Heard today that the HTHS of the racing 20 is (was August 2013) 2.5, which makes it a 16 as well.
For info, the
5W30 HTHS is/was 3.34
10W40 HTHS is/was 4.49
