Hi all -
Toyota Tercel, 1999, 290,000 km. I was under the car doing rust-spraying and took a look at the underside of the water pump. I was surprised to see a fair amount of crust under the weep-hole.
Thing is, it's not making noise (I stuck the stethoscope on it and it sounds just like the alternator and steering pump sounds, save for a very faint clicking noise).
I am also not leaking coolant noticeably. I had to fill up the reservoir when it reached the minimum level (about a half-pint to a pint), that was after 1 year since it was last drained and filled to the max level. I have also seen my upper radiator hose has the slightest leak around the clamp. It doesn't look the greatest so I'll be changing the hoses anyway.
So, is crust around the weep hole terminal? Should I change it out before it strands me? Or is that normal after 290,000km and 18 years? Remember, no unusual noise or grinding, even with the stethoscope. Since I'm changing the rad hose, should I just change it anyway since the system will need to be drained?
I know that this mileage is your typical OEM water pump's end of life. My inner voice is telling me to change it. Does the community concur?
