Originally Posted By: fdcg27
No need to change oil that's close to new and no need to change it every 3K either.
Fill the tank with fuel, drive it straight into the garage, shut it down and then leave it be. Some sort of battery tender/maintainer would be a better use of you money than an oil change.
In the spring, start her up and drive.
I've stored cars in this way for years with never a problem.
+1
My 2002 Acura TL has yet to see a Canadian winter, has been stored pretty much in this manner.
I add fuel stab on the last fill up. Crack the windows down 1" and throw the car tarp on it.
About 4 or 5 weeks later I start putting the trickle charger on the battery for a few days at a time, and pray for an early spring...
Edit: wanted to add... OCI are approx 10k km ... if im relatively close to that ..I will change the oil before... this year I am NOwhere close... oil is staying in....
