The higher the flow through the media, the less filtering the media is doing, unless the overall area is increased. No media whatsoever would make a very high flow "filter".
You want some flow restriction because the fluid is going through filter media, and you want to minimize flow restriction due to tight bends, routing of lines, type of fitting, restrictions in internal passage diameter, etc.
