Hey everyone.
I own a small scooter that has a CVT (dry clutch) and a separate final drive that has its own fluids, completely separate from the engine.
The max rpm this scooter see is 9000 rpm.
I've been reading a lot on this topic and I can safely conclude that:
1/ The whole JASO thing is about wet clutch. I have a dry clutch, so no need for that.
2/ The claim that gears in the engine case of a motorbike will "squash" the oil somehow. I don't have gears inside my engine, the final gears are separate. my engine oil lubricates only the crankshaft, crank bearings, cylinder/piston and camshaft. So I don't need to care about this.
The thing that sticks with me though is how a car rarely goes over 6000 rpm (this is true) and a small engine like my scooter sees 6000 rpm everyday, although my engine is water cooled, not air cooled, the engine temp tends to be stable at 100 degrees celsius during normal operation.
my question is can high rpm wear down a car oil so much that it becomes a concern to use in my scooter? My friend works at a car dealer and he can get me a whole load of cheap synthetic car oil so if it's OK I can save myself a lot of money instead of having to use "bike oils" just to not having to worry about the high rpm tearing the oil apart or something like that.
Thanks.
Thanks.
